WTB: A10 or 1200 timing case
As the tittle suggests need, a A10 or 1200 timing case. (pre '74 would be ideal) make a offer. In Melb, but will pay postage. cheers
Posted on: 2008/9/10 5:49
Re: WTB: A10 or 1200 timing case
From Adelaide, Australia
just be carefull on A10 timing covers as there are 2 types. they look the same to the naked eye but when u goto put it on its slighly different. no one belives me that there are 2 but there are.
Posted on: 2008/9/10 6:34
yeah, cheers for the heads up! this is what 'Dodgeman' said as-well
"ALL A series timing cases are interchangeable, but they are not all the same.
The A10 & 1200 engines used a timing cover with a single timing indicator in the timing case & several timing marks on the pulley. From 1974 [I believe] the situation was reversed & the timing case was cast with the various timing marks cast into the case & a single mark in the pulley."
I've found one from a wreckers in SA, he said there is no difference, and wouldn't take me word for it, so i'd rather get one of someone from here.
Posted on: 2008/9/11 1:48
My B10 parts book shows three part numbers.
13035- 18000 Assy-cover Timing chain. [to E/# A10-184227] [This is for the earliest engines with the single row timing chain]
13035- 18001 Assy-cover Timing chain. [from E/# A10-184228] [duplex timing chain] Not interchangeable with former.
13035- H1000 Assy-cover Timing chain. Interchangeable with previous unit, but not the first.
Two part numbers for the Datsun 1200.
13035- 18001 Assy-cover Timing chain [Up to 04/70]
13035- H1000 Assy-cover Timing chain [From 05/70] [Interchangeable with former part No.]
Note that these two numbers match the last two numbers for the A10 engine.
The earliest A10 engines used a single row timing chain with its own timing case. When they switched to the duplex chain, the timing case was also changed & this one had a guide for the chain.
The replacement timing case, from 05/70, deleted this guide as it was found to be un-necessary.
So yes, Matto1kUte is right, there were basically two non interchangeable timing cases.
One for the single row timing chain in early 1967 models &
One [in two versions] for the duplex timing chain.
The entire duplex timing chain, sprockets, hydraulic adjuster & timing case from the later model engine is interchangeable with the early. single row type as a complete assembly.
Posted on: 2008/9/11 4:25
Love your Datsun.
Treat it well.
Hi Dman, it looks like from the parts catalog that A10 used a fix tensioner -- and not the hydraulic tensioner that the A12 has?
Posted on: 2008/9/11 5:26
From Geelong, Vic
ive got plenty of late model ones, from mid dizzy engines
can give you as much stuff as you need off the eninge
Posted on: 2008/9/11 5:31
sorry PIGDOG, haven't had the net the last few. check your PM. cheers
Posted on: 2008/9/16 0:30
