« 1 (2) 3 »
Re: Stupid Door
From Wagga Wagga, NSW
bob or me? mine still sucks!! fix one problem and then theres another one!
Posted on: 2008/9/10 9:40
Re: Stupid Door
The door & it's hardware are just inanimate metal mechanical devices, while we, .. on the other hand, are infinately inteligent beings capable of puting man on the moon with less computing power than I have in my PC.
Tell me, .. why is it the 'door' that's stupid???
Posted on: 2008/9/10 9:47
Love your Datsun.
Treat it well.
Re: Stupid Door
Because everytime i replace something that is broken in it, something else breaks. So i called it stupid.
Posted on: 2008/9/10 10:09
Re: Stupid Door
From Adelaide, Australia
Make sure the clip hasn't fallen off the back of the lock, all internal door mechanisms are attached properly, if some are loose might cause them to bind.
Posted on: 2008/9/10 10:12
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Stupid Door
From Melbourne, Australia
hammer = break
perhaps you should stop useing the hammer so much!
Posted on: 2008/9/10 10:16
Re: Stupid Door
ill check all the clips and those pin things again tomorrow. ill try the silicone spray too.
haha its the only time a hammer has ever touched my ute. it'll never happen again!!
thanks for the help so far!!
Posted on: 2008/9/10 10:20
Re: Stupid Door
Momo-I was refering to Bob I recently competed in a motorkhan/khanacross event at albury with Bob and his doors wouldnt stay closed soo he used a hockey strap to keep them closed during the event, It was quite funny.
Jake
Posted on: 2008/9/11 0:44
Re: Stupid Door
Just off topic- you going in motorkhana this month jake? im thinking of giving it a go, or coming for a squiz. kurrajong reserve is it?
Posted on: 2008/9/11 1:08
Re: Stupid Door
From Brisbane
That is assuming that man actually landed on the moon! Remember if there is no air in space, what was making the flag wave in the "wind".......................Freaking idiots....
Anyway. Put that hammer away, and don't even look at your poor datsun with it in your hand ever again. As people have said, pull your door cover off and have a look and give it a spray with WD40. If that dosn't work, pull the sucker out and put it on the bench and have a better look. When you figure out what the problem is, check the other side and make sure that side is ok. GET TO IT!
Posted on: 2008/9/11 2:04
Re: Stupid Door
Yer ill be there this month mate,albury is coming down too for an interclub challenge so hopefully Bob will be down with his nipy little ute, Its on the 28th at kurrajong reserve! Hope to see you out there mate would be awesome if you entered your ute.
Jake
Posted on: 2008/9/11 2:22
« 1 (2) 3 »
