WTB LATE UTE CASTER RODS
anyways, nick you will just need the normal
stanza sunny or late ute control arms
late ute castor rods
stanza/sunny balljoints
stanza/sunny steering arms
late ute or stanza out tierod ends
" " tie rods
thanks alot nick
Posted on: 2008/9/15 11:01
Car free
Re: looking for this stuff please help
BUMP
BUMP
Posted on: 2008/9/16 10:45
Car free
From Adelaide, Australia
Dont reuse balljoints and rod ends. The tie rods themselves should all be the same length so use your 1200 ones.
You can add late 120y castor rods to your list.
Posted on: 2008/9/16 11:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
going to buy the new
balljoints and tierods not needed just need lca's and steer link and caster rods and stanza hubs or stubaxle wat eva you call em
Posted on: 2008/9/16 11:05
Car free
whats wrong with re using ball joints if you know they are ok
Posted on: 2008/9/16 11:11
I think that the point is that you can't vouch for a second hand ball joint. But I disagree with using the stanza balljoints and tierods. All you get is a wider track with a little extra neg camber. The castor remains the same. Use a set of maddat or simular strut tops and then you can have the best of both. Just ask mik about the stanza ball joints. scrub scrub.
Posted on: 2008/9/16 11:19
From Armidale N.S.W
New ball joints etc bud. He has kids, That's whats wrong with using second hand ball joints etc. Safety first for kiddies on board
Posted on: 2008/9/16 11:43
73 1200 wagon SOLD
bump come on people someone must have some stanza lower control arms and steering arms and hubs or stub axles wateva u call em, and late ute caster rods
please help this is all i need to finish my breaks
Posted on: 2008/9/19 2:41
Car free
Quite a regular
Thems the brakes!
Posted on: 2008/9/19 3:27
??? What do you mean?
I've been driving vehicles with second-hand ball joints for 27 years in all sorts of vehicles, never had an issue with them. There are several ways to tell if ball joints are bad. And you can tell if they are good. There is no mystery here.
Posted on: 2008/9/19 3:57
