« 1 (2)
Re: valve spring installation question
From Perth WA AUS
I dont know, but talk to Dundee1000, he sells them for a great price
Posted on: 2008/10/8 13:33
Datsun 1200 2Dr sedan.
From Cape Town ZA
Mmmm, we've always installed them with the "coils closer together" against the head, ie. the bottom. The coils being closer means that that end of the spring would be heavier, so that you're now moving more weight with the tappet, with obvious negative consequences. Also the reason for these types of springs are, that they become progressively stiffer as they compact with the less denser coils compacting first and then the dense ones.
On other cars there are sometimes paint marks on the one end of the spring, with no difference in the coil density, and these paint marks are always against the head when you strip. So we tend to reinstall them the way they came out, but if there's no markings or obvious differences in the coil density on either end, then it shouldn't make a difference which way they go in..
Posted on: 2008/10/8 14:53
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From Freo
Hiya Guy's,
yes we can supply double springs,
GX spec and 10k rpm ones...
the seats, collets and retainers to suit,
Billet rocker spacers, and Tomei pushrods...
all the fruit...
Pm for details.. :)
ps I've always installed the springs, tighter coild towards the head.. for the same reason as mentioned....
Posted on: 2008/10/9 1:40
A15 PSI Project Motor
'72 CB750k,
Not too shy to talk
From Loveland, Colorado
Thanks for the replies! So, assuming that the tighter coil end should be installed towards the head, would installing them any other way create a noise issue?
Ever since getting a valve job done a month or two ago there has been a noise in the valvetrain that I haven't been able to figure out. It moves with RPM's, so that is why I figured it might be the valve springs.
Posted on: 2008/10/9 4:35
From Freo
are the tappets adjusted correctly?
has there been a head or cam change?
Posted on: 2008/10/9 9:42
'72 CB750k,
From perth
tight end of spring is heavier.we dont want the moving end heavy do we? closer coils at one end also increase spring RATE as the spring is compressed
dazza
Posted on: 2008/10/9 12:34
Not too shy to talk
I've adjusted and readjusted the valve clearance numerous times and that noise is still there. The head is the same as was on it before, just new guides, a regrind on the seats and resurfacing were done to it. The cam is stock.....I didn't touch the bottom end.
I plan on rechecking valve clearances and removing the valve springs this weekend to see what it all looks like.
Posted on: 2008/10/9 13:48
From perth
excessive guide clearance?
were the guides replaced or klines fitted
reamed to size or honed?
klines hate rough finish on valve stems
is it smoking?
dazza
Posted on: 2008/10/12 6:07
« 1 (2)
