(1) 2 3 4 »
my vb10, 1600s and my brothers zed
Quite a regular
Posted on: 2008/10/9 4:28
Re: my vb10, 1600s and my brothers zed
From The garage, NZ
crazy jelous of your garage!
Nice choice on the bike carbs and the dattos are looking smooth
Posted on: 2008/10/9 5:20
some1 been busy with 3 of the best dattos ever!
Posted on: 2008/10/9 6:31
Quite a regular
Yep been busy in the shed. The vb10 should be painted in the next few days i hope. Still needs two coats of primer.
The carbies i am using on the a10 are off cb900. hopefully put a cam and valve springs in aswell. Bring on 9000rpm 1L grunt haha.
Has anyone ever heard of the a10 cranks breaking?? I wouldnt think they would be
particualy strong with 3 main bearings.
Also which brand of extractors fit a10's in 1000's. The engine mount looks like it may foul with most extractors
Posted on: 2008/10/9 8:37
Lampy Mate,
You will probably have to roll your own exhaust up as I don't think anyone stocks them (unless you buy from bprojects), I'm rolling my own up. Although my alignment (1200 extractors) fouled with the intake manifold as well as the engine mounts and the firewall belly (too close).
The A10 should be okay with it all, I would say turboing would be bring some issues. Carbs should be fine. Throw some double valve springs on and that should help you get the revs that you want.
Well, having three bearings wouldn't compare to 5 on the later A-series models. Give it a go, in the meantime grab a spare engine in-case things do go wrong.
Posted on: 2008/10/9 8:49
From Freo
Where are you located Lampy?
another VB10 in Perth..
Posted on: 2008/10/9 9:40
A15 PSI Project Motor
'72 CB750k,
From Wagga Wagga, NSW
Nice carbys mate are they 36mm keihin's? Ive got the same carbs if thats the case im putting on my ca18de bring on 9000rpm!!! haha sweet rides man
Posted on: 2008/10/9 9:46
Quite a regular
Hey Dundee
Nah not in perth. Used to be there but in vic now due to work. Might be coming back sometime next year though.
I might be after a few bproject bits, ill give you a PM.
Posted on: 2008/10/9 9:49
Quite a regular
yep they are 36mm keihins. I also have 39mm keihins off a cbr1000. Might swap a few jets from each to get it tuned better. Have you got a source for jets and needles?
Posted on: 2008/10/9 9:52
Nah im yet to atempt tuning them let alone fitting them to my motor
Posted on: 2008/10/10 10:08
(1) 2 3 4 »
