WTB CA18DET stuff
From Geelong, Vic
need a fair bit of stuff for my CA to get running....so thought i'd see if anyone here has any of it spare
all the stuff i want from a CA18det, or a DE if its the same thing
engine loom
ECU
turbo manifold
injectors
air flow meter
ignitor
injector resistor pack thingo if its needed
CA manual bellhousing
flywheel and bolt if different to flewplate ones
clutch pressure plate
think thats about all for now....will add anything that ive missed
Posted on: 2008/10/14 3:36
Re: WTB CA18DET stuff
i have a det loom thats been molested for conversion was in my bluebird.
i have a de loom that has not been modified.
have na injectors but i would have to say they are different from turbo.
ecu are different but can use NA if getting a remap
i have a airflow meter, should have an igniter too and that other thing. not sure
have CA20 box that i will seperate bellhousing.
im in adelaide so stuff would need posting. could be worth it for stuff like loom and airflow meter.
if your interested make an offer. i am not sure whats its worth. its just stuff that came out of my old car when i killed it.
Posted on: 2008/10/14 4:45
From Adelaide
pm'd ya dog
Posted on: 2008/10/14 5:55
From BRISBANE, QLD
pm sent
Posted on: 2008/10/14 6:13
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
From Mackay QLD
pm sent mate
Posted on: 2008/10/14 10:15
From Geelong, Vic
bump
Posted on: 2008/10/15 2:10
From Newcastle
i got AFM and turbo injectors. .
Posted on: 2008/10/15 3:19
From perth
turbo injectors low impedance different key on plugs
turbo harness has dropping resistorrs
turbo harness has prscv (solenoid to bump up fuel pressure on boost)
turbo harness has boost conrol solenoid
na high impedance injectors
harness has no dropping resistors ,no prscv, no boost control solenoid
mine has (had) one wire ego, turbo has 3 wire
na harness can be spliced with turbo if you have both (this is what im doing)
i have all wiring diags if you need and ecu pinouts (corrected as they had mistakes)
dazza
Posted on: 2008/10/15 12:37
From Geelong, Vic
bump, need prices
Posted on: 2008/10/17 9:38
