« 1 2 3 4 (5)
Re: help req for sc14 SETUP METH/WATER INJ
From Christchurch NZ
you can make you're own kit pretty easy. You either use a washer bottle, or a pressure resovoir. If you do a google search, the net should be swimming in info on how to build them
Posted on: 2008/10/23 6:42
Forced Induction!
thanks ive already got one i think just got to work it out ill post a pic later. i got the setup that was in grunters car
Posted on: 2008/10/23 8:44
Car free
From Stray-ya
Water meth injection........
let me think. there was a blue wire..... a red wire ..... a black wire..... a little light..... a solenoid.
Nope, don't remember how it went together.
When I sold the car I sold it with a massive folder full of reciepts and instruction books. the instructions were in there along with a photocopy of the manual for the SC12 (essentially the same as the SC14) your best bet is to track these down. SC12's and 14's are almost completely non-servicable, so check the oil and leave it at that. If you try and take it apart you will end up with a big bill from hard to get toyota genuine parts. the main assembly (lobes & gears) are pressed together at the factory and if you try to take them apart you will bugger it for good.
if it ain't broke......
You may also be able to track down the water injection on the web. I bought it online. had a name like supercool or aquamist.
Good luck with it.
Posted on: 2008/10/23 15:33
Utes and Roots
From Stray-ya
EDIT:
here's the kit.
http://www.aquastealth.com/watermethanolinjectionkit.aspx
friggin $60 us cheaper now than when I got it as well.
Posted on: 2008/10/23 15:39
Utes and Roots
« 1 2 3 4 (5)
