Weird Electrical Problem
From Armidale N.S.W
Here goes another one. When i put my left indicator on the front ones flash as normal but on the rear my Right one flashes and the left one does to but very weak hardly visible. Then with the Right on The Front Rights Flash and rear Right Flashes as normal. Also with headlights on the tail lights flash as well with both indicators on.
What The ???
Posted on: 2008/11/1 8:36
73 1200 wagon SOLD
Re: Weird Electrical Problem
From south coast, nsw
sounds like u have poor or broken earth wire or connection somewhere at the rear lights
Posted on: 2008/11/1 8:43
Yep,u may wanne check out on your rear and front lights wether the wires may be touching each other...also check ur light switches inside the car for wires touching...
Posted on: 2008/11/1 9:00
From Armidale N.S.W
The Weirdness has grown. When i put the car in reverse with left or right indicator on they stop working When i put my foot on the brake the indicators Wont work.
Posted on: 2008/11/1 9:33
73 1200 wagon SOLD
From 6065
Yup thats just like the p-nut after i painted over the taillight earth then that happened when i put it back together. it should be the taillight earth.
Posted on: 2008/11/1 9:43
From hastings,vic
u have a earth problem 100%
other lights are working when thay are not ment to be because thay are supplying earth for the light that is ment to be working. check earths on tail lights ,run more earths to lights
tommo
Posted on: 2008/11/1 9:57
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
its usually from the drivers side tail light to the area behind the trim neaer the fuel filler neck. i have had the problem too
Posted on: 2008/11/1 23:37
From Armidale N.S.W
THANKS EVERYONE. We put a thicker black wire in place of the original earth and also added another thick black wire to the passenger side Reverse light earth. Then put a small nut and bolt with washers including spring washers attaching them to the body nice and tight. WALLAH we have all lights functioning correctly again. BIG THANKS AGAIN PEOPLES. Some things seem so easy when there fixed. This Sight And Its Members Rule.
Posted on: 2008/11/2 1:55
73 1200 wagon SOLD
