(1) 2 3 »
electronic ignition 4 L20b
From Albany, Perth Australia
hey guys i am looking for and authentic electric ignition for an L20b to upgrade from the points type, does anybody have one they dont want or know of where to get one?
Thanks
Posted on: 2008/11/11 8:30
1200 Smerf Mobile
Re: electronic ignition 4 L20b
From Adelaide, Australia
Have you seen the petronix kits?
Did you use the dizzy I sent you?
I have a S2 bluebird dizzy if your keen, I don't know if it works or not.
Posted on: 2008/11/11 8:35
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
yes i did use it and am still using it but the pertronix electronic ignition doesnt work without major modifications and it still uses the vacuum advance but you cant bolt it on
Posted on: 2008/11/11 8:50
1200 Smerf Mobile
Use porsche bosch points they will fit the L-series bosch distributor, get high density foam cut a small triangle peice and place between spring and points arm to help with bounce.
Posted on: 2008/11/11 8:58
IPRA Build
the problem i have is that i have lost all high revs under laod due to no vacuum advance and want to get rid of the whole idea, and as i am selling it i want it to go like how it is meant to...unless there is a way to get it to work with my webers?
Posted on: 2008/11/11 9:02
1200 Smerf Mobile
What base timing are you running? You need to have about 12-16
Posted on: 2008/11/11 9:08
IPRA Build
Posted on: 2008/11/11 9:25
1200 Smerf Mobile
so what is the s2 bluebird dizzy? is the electronic dizzy? and does it have the vacuum advance or not?
Posted on: 2008/11/11 10:01
1200 Smerf Mobile
Im pretty sure it would have the vac, can't remember looking at it too hard, but yes its the eleccy one..
No it won't cure your problems, you need to take the dissy and get it set up with a different curve if you don't have the time to do it yourself.
Posted on: 2008/11/11 10:06
IPRA Build
i know there are some that dont have a vacuume advance. Why cant anything be simple(chucking a temper tantrum). I have spent long hours getting things fixed and now i have to start working saturdays again which means no time for fun other wise i would do it myself. I do have a question if i was to attach the vacuum advance to the webers(like where the brake booster hose would go but on the other side) would that work?
Posted on: 2008/11/11 10:17
1200 Smerf Mobile
(1) 2 3 »
