Browsing this Thread:
1 Anonymous Users
Re: EOI: wrecking 120y. Lots of good bits. |
From Canberra
Diff, struts, bigport inlet manifold and GZE injectors sold pending payment.
Posted on: 2008/11/15 7:59
From Canberra
cooler and radiator sold pending payment, diff sold.
Posted on: 2008/11/16 7:21
From Canberra
swaybar, struts, booster/master, brake bias valve sold
Posted on: 2008/11/17 9:36
From Canberra
What is left:
$100 OBX Daytona black fixed bucket + rails $150 steering wheel/boss, door trims, dash etc
$50 - Clutch master setup suit 120Y $20 Solex locks + all keys $80 - 2.5 mandrel bent Exhaust dump back (not including dump) $200 13x5.5 hotwires, tyres x6 $200 120Y fuel tank with extra fitting/s, lift pump, surge tank, 070 main pump, 3/8 main line.
Engine AE92 4agze (no comp in no.4) - $400 T50 gearbox - $300 Autronic SMC+loom+modified CAS - $1500 Custom Nissan ballbearing T3 turbo, highflowed, polished front housing, Ceramic coated rear. Custom ceramic coated steampipe manifold (fits ae86 and 120y, probably others), 2.5 dump pipe, Speedflow braided oil feed line/Tpiece. Sump with oil drain, Braided water lines. Autometer Pro comp ultralite boost gauge+cup. $1300 200mm exedy brass button clutch $150
Cut/shut (well) smallport inlet manifold suit RWD $150 Blitz BOV with pipe $100
Engine/gearbox mounts to fit 4ag+T50 into 120Y $200
Posted on: 2008/11/19 8:34
