F5C56A help
From Portugal
I havea 56A 5 dogleg five speed that needs to be fixed.
One bearing is completelly destroyed and the sincros are in bad shape.
Were can i find some new sincros, or can i make new ones?
And what about the rebild manual? were can i found?
thanks in advance
Posted on: 2008/12/7 15:15
Re: F5C56A help
From NZ
Not sure if you can get new syncros but you can replace them with standard 56A syncros (eg servicable used ones). May need to replace each pair if the ones in your 5 speed are the steel type rather than brass liek 4 speeds.
Bearings - take the worn ones to any bearing outfit and ask for replacements.
Posted on: 2008/12/8 10:26
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Re: F5C56A help
From Portugal
the standard 4 speed syncros fits the 5 speed 56A gearbox?????
Posted on: 2008/12/8 18:01
Re: F5C56A help
4-sped and 5-sped synchros are very different.
Nissan Part Numbers
4-SPEED
EARLY
* 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED
* 32604-H1000 BAULK RING
* 32606-18000 SLEEVE-COUPLING
LATE
* 32601-H7301 HUB-SYNCHRONIZER, 1ST & 2ND, 3RD & 4TH
* 32604-H9000 BAULK RING
5-SPEED
* 32601-H7200 HUB-SYNCHRONIZER, 2nd & 3rd, 4th & 5th 5-speed
* 32606-H7200 SLEEVE-coupling
Posted on: 2008/12/8 23:44
Re: F5C56A help - rebuild manual
Here is the repair manual you will need:
or Open in new window
Factory Service Manual
Posted on: 2008/12/9 7:59
Re: F5C56A help
From NZ
Yes - but they can be swapped for the standard brass/4-speed type and work fine. You'll need to press the cone off the gear and press on the one to match the brass type. Works fine in my one
Posted on: 2008/12/9 9:14
Re: F5C56A help
You have a 60-series 5-speed, right?
Posted on: 2008/12/9 9:25
Re: F5C56A help
From Portugal
DD i have that manual, but dont have the 56A five speed
Posted on: 2008/12/9 12:43
Re: F5C56A help
You may need the Japan-market service manual, since that was the only place this transmission was sold. It will be in Japanese, but all the measurements are easy to pick out.
Posted on: 2008/12/13 10:28
