help needed A12 b310 wont go
From auckland, new Zealand
hey guys i am in a slight predicament at the moment.
i noticed the cap and rotor were looking a bit worse for wear on my beige bomb so decided to change them, i have put brand new ones on and now she wont start!
i put the old ones back on just in case their were faulty parts or something, nope she still wont go.
i have checked that there is spark and fuel, i thought i may ave somehow hit the points and moved them, but they are gapped up sweet and on time as well.
im soooooo confused any ideas?
Posted on: 2008/12/13 1:50
Re: help needed A12 b310 wont go
From Bathurst - NSW
Check that you're not out 180 degrees with your rotor, double check the firing order, 1 - 3 - 4 - 2 in an anti clock wise direction
Posted on: 2008/12/13 3:15
yup firing order is fine, and rotor only fits on one way.
any other ideas?
resistor wouldn't do this would it?
Posted on: 2008/12/13 3:41
From Armidale N.S.W
resistor is a possibility or condenser.
Posted on: 2008/12/13 4:30
73 1200 wagon SOLD
From Sydney
Have you moved the distributor at all?
Is it almost starting with a backfire?
If you have fuel and spark at the plugs and if the firing order is correct the only other reasons it wont start is timing or compression. Since you have been playing with the dizzy im guessing its timing but you shouldnt mess it up replacing a cap and button. Im thinking along the same lines as BRUTE, is most likely something very simple. Tripple check firing order and make sure you know which is No1 on the cap. Make sure cap is fitted correctly and look really hard for a wire you may knocked of the coil or the side of the dizzy.
God luck
Posted on: 2008/12/13 4:33
From Melbourne vic
the old put the leads back on assabout trick
love that one!!
Posted on: 2008/12/13 4:43
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
no i haven't moved the dizzy, and it almost started but dies once, thats as much as i can get from her now.
condensor aye, i'll have to look at that, all wires are still conected that i can see.
Posted on: 2008/12/13 4:52
From Armidale N.S.W
yeah i had a similar problem replaced the condenser and wa lah she went like a dream.
Posted on: 2008/12/13 5:37
73 1200 wagon SOLD
I've had this happen several times... it was always the plug wires being off. Even with the right order, if they are off it's easy to put them on wrong.
Posted on: 2008/12/13 6:21
From Sydney
does the motor sound like its running ok before it dies or do you think it has missfire?
Posted on: 2008/12/13 7:51
