(1) 2 3 »
12" Wheels and tyre sizes
From Wallan, Vic, Aus
Hello, I wanted to know what the widest tyres that can be put on a standard datsun 12" rim or if there is other 12" rims out there that have a wider tread? I saw some once a long time ago, they were 12" and had 205s or something. Quite an off set too.
Posted on: 2008/12/13 1:45
Re: 12" Wheels and tyre sizes
mini guys have access to 165 65 12 and 175 65 12 so you cold find some but they cost more than 195 50 15 tyres
Posted on: 2008/12/13 3:02
well thats annoying. but thanks for the info
Posted on: 2008/12/13 3:36
i have 165/55 12" Radials on my 1200.
The 12-inch Datsun wheels are only 4" wide. Technically the maximum width tire would be a 175. However, you see that people 'stretch' wider tires onto rims...
Posted on: 2008/12/13 5:18
From The garage, NZ
lol, get those things widened! 12" steelies are the tits
Posted on: 2008/12/13 9:27
From Sydney Australia
I am getting some quad bike rims. They are 12x7's and cost $90 each brand new! The pcd is 110 but I will just get them redrilled to the correct spacing. Thanks for the heads up cheats.
Posted on: 2008/12/13 11:06
Are quad wheels certified to go 140kph and carry 700kg per wheel? The Datsun 1200 steel wheels can handle that...
Posted on: 2008/12/13 11:12
They are designed for racing quads that do 60ft jumps so I believe they are okay. The man from the shop believed they are well and truly up to the job.
Posted on: 2008/12/13 11:16
What the man from the shop believes & what the rims are certified to cary may or may not be the same thing.
I wonder if the man from the shop would be prepared to cover any financial or legal liability if they should not live up to expectations.
Do the quads actually do a vertical drop of 60ft? I suspect not.
The quads also weigh a lot less than a Datsun.
Posted on: 2008/12/13 15:43
Love your Datsun.
Treat it well.
From The garage, NZ
Thats so awsome, tip of the hat to you laney. Go for 12's on a 1000 is the best thing you can do, I mean look at berts one on 10's!! jeebus thats hot.
Hope they hold out, i want to see em
Posted on: 2008/12/13 21:06
(1) 2 3 »
