Browsing this Thread:
1 Anonymous Users
Re: (mattdatca18 1200 ute) my ute have a look ppl |
From townsville qld
hi datsunsunny yer as frank said im not nunning that set up it is the stock s13 booster and master cos there was no room for the clutch master but i am running a remote booster i will get to it in the thread bud
cheers matty
Posted on: 2008/12/7 7:11
once you go boost you will never go back haha spool it yo lol ca18det 1200 ute ,fmi,microtechlt8,turbosmart bov,= v8 eater
From townsville qld
hi hotrocket yer the stock gearbox mounts where removed and just the back of the tunnel was cut out for the s13 5 speed to fit but i have a full custom engine x/member that sits the motor as low as it will possible go then the gearbox just fits but if u want to change the clutch u have to drop the motor out
cheers matty
Posted on: 2008/12/7 7:22
From townsville qld
Posted on: 2008/12/7 7:48
From townsville qld
time to start putting all the good bits on. well the brakes where the first thing i changed from the standard drums to stanza front disc and stanza LCA's and on the back i think they are bluebird adapter plates with disc's and the master cylinder is 11/16 running a vh40 remote booster
Posted on: 2008/12/8 7:15
From townsville qld
Posted on: 2008/12/8 7:24
From townsville qld
Posted on: 2008/12/8 7:30
From townsville qld
now its time to put the brain for the ca18 and the ute loom ive hidden all the wiring up under the dash so that under the bay looks neat also the heater went in at the same time
Posted on: 2008/12/9 9:06
From townsville qld
ok so now its time to drop the motor and gearbox in and start connecting all the wires and fule lines
Posted on: 2008/12/14 11:43
From Sydney, Australia
Showing some good progress. But from my experiences, you are going to need to trim the gearbox crossmember to clear the exhaust pipe from the turbo to the CAT convertor. Keep going. You still have a long way to go!
Posted on: 2008/12/14 20:43
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
From townsville qld
hi dattodude yer the gearbox crossmember did get a bit of a trim with the grinder and im running a (suppercat) so i dont need a cat then a muffler it sits nicely between the cab and the diff Quote: dattodude wrote: Keep going. You still have a long way to go!
dont tell everyone but my ute is running and on the road just doing a thread on it
Posted on: 2008/12/15 6:45
