(1) 2 3 »
difference betwenn a14 and a15 blocks
From nowra nsw
difference betwenn a14 and a15 blocks like is the deck height bigger ect and iv already done a search
Posted on: 2008/12/20 0:46
Re: difference betwenn a14 and a15 blocks
From Melbourne, Oz
Datsun A14 Engine
Bore: 76mm
Stroke: 77mm
Conrod: 133mm
Block Hieght: 204.1mm
Displacement: 1397cc
Power: approx 78hp
Datsun A15 Engine
Bore: 76mm
Stroke: 82mm
Conrod: 133mm
Block Height: 204.1
Displacement: 1488cc
Power: approx 81hp
Yeah the deck is higher, I'd emagine buy the same diferance of the strock's? but the conrod's may be different??
Posted on: 2008/12/20 1:18
"I hav achieved wood"
Datsun A14 Engine
Datsun A15 Engine
Block Height: 204.1
Why do you say the deck is higher? I reckon they are the same.
In any case, the two blocks are significantly different. The A15 block has cast-in 'A15' on the side, and has cutouts in the lower part of the block for the larger crank counterweights. There may be other differences. Somewhere around here we have a comparo photo.
Posted on: 2008/12/20 2:24
From Melbourne, Oz
I dident even notice that, but that comparo pic is what I was thinking of when I sed that, I was sure it was a little taller?
Posted on: 2008/12/20 5:00
From Melbourne, Australia
same height
Posted on: 2008/12/20 6:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne, Oz
that mean's it's rods must be shorter? that would be #### for the serch or RPM's!
Posted on: 2008/12/20 6:26
From nowra nsw
so if you put an a15 crank in a14 block u basicly have an a15 right
Posted on: 2008/12/20 6:27
Nope. A15 crank won't fit into an A14 block.
The rods may be the same length. If so, the piston pin height will be different. It could be done either way.
Posted on: 2008/12/20 6:34
From nowra nsw
how come the a15 crank wont fit
Posted on: 2008/12/20 8:26
From Melbourne, Oz
the counter weights hit the block. I has bin done but with modification..
Posted on: 2008/12/20 8:29
(1) 2 3 »
