« 1 (2)
Re: Going to build Tramp rod/caltrac set up
From sydney
couldn't you just use them on both sides? why is it neccessay for them to pivot?
Posted on: 2008/12/23 11:34
From Cape Town ZA
Myself and my dad built these from marine diesel headbolts, some steel stock, left and right hand nuts and Jaguar suspension mounts. Have a look if it's of any help...
The parts...
Welded up...
Here you can just about see them stick out under the car...
Posted on: 2008/12/23 18:33
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From The garage, NZ
anyone have a pic of said whiteline rear swaybar in a 1200?
Posted on: 2008/12/23 19:54
From gold coast QLD.
Personally,i would have thought a Bluebird rear bar would be way too big(thick)not that i know what they actually measure.
My gut tells me i would'nt go any thicker than 12mm on the rear of a 1200.
I used 10mm solid mount on the back of the KB10 in competition.
Posted on: 2008/12/23 20:22
I think you're referring to my rear swaybar Bert. The rear bluebird swaybar measures 20mm. When mounted like in the configuration from the datsun manual it was way too stiff. I made it work however, by bringing the U clamps inwards on the diff housing reducing its effectiveness.
I did some wet laps around Phillip Island with the rear swaybar just installed and way too stiff. It was terrifying at best!
Posted on: 2008/12/23 23:45
From Kingsley, Perth, WA
Check out http://www.hotrodsandhemis.com/Traction.html and http://www.calvertracing.com
I copied the first sites instructions when I made mine for my ute. I went and bought 4 chromoly rose joints from the local bearing shop and inside threaded two half-inch steam pipe sections and they worked beaut.
Posted on: 2008/12/24 4:46
« 1 (2)
