Browsing this Thread:
1 Anonymous Users
Advice on rear shocks |
From Perth, Western Australia.
Just wondering if anyone can give some advice on what rear shocks to run on my 1200 coupe? Mine are completely shagged. I've got standard leafs that have been reset pretty low so I want something fairly stiff as I don't think there will be too much clearance with the new rims on. Thanks
Posted on: 2008/12/30 4:58
Re: Advice on rear shocks |
From Perth
Have you got a budget in mind? If the spring rate is significantly higher you should get shocks to match (ie. revalved) otherwise the shock will not be able to control the spring.
I would be looking at Koni's or Bilsteins depends on the budget though.
Posted on: 2008/12/30 5:01
Yeah I didn't really want to spend too much as it's just for my girlfriends daily. So I don't need anything perfomance orientated, just something stiff enough to keep the tyres off the guards. The guy I get my suspension gear from said that he couldn't find anyone that does shocks to suit?
Posted on: 2008/12/30 6:27
