1400 Turbo motor blowing head gasket
From South Africa
do i need to lower comp. ratio to stop my 1400 turbo motor from blowing the head gasket,do i need a thicker one or can you put 2 on?standard comp ratio 9.4,was i running engine too rich?
Posted on: 2009/1/9 12:43
Re: 1400 Turbo motor blowing head gasket
From Armidale N.S.W
8:3:1 is what my mechanic recommended you can get thicker head gaskets or high rise ones using 2 is dodgey but it works.
Posted on: 2009/1/9 12:49
73 1200 wagon SOLD
From Melbourne, Australia
depends on what boost you are running also
lower comp essential allows you to run more boost before detonation. but lower comp is bad for off boost performance
for a street car maintaining compression and keeping boost lower makes for a much nicer car
Posted on: 2009/1/9 13:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From South Africa
I am still waiting for a fuel regulator so i have just got a fuel pump feeding it to a 38 dgas blow through and am not sure what boost i am running at as i still need a boost gauge. I have a IHI RHF5 turbo from a merc diesel i think, but the car has quite a pull till it starts suffering from feul starvation,i think i'm running too lean?
Posted on: 2009/1/9 13:28
is it blow through or suck through setup
you NEED a boost gauge straight away
what fuel pump are you using?
if your using blow through the boost pressure may rise above the fuel pressure and be essentialy pushing the fuel back up the fuel line
pictures of the setup and a hell of a lot more description are required
Posted on: 2009/1/9 13:31
1200 Coupe Rallycar
From South Africa
Posted on: 2009/1/9 13:43
From Krugersdorp,Gauteng,ZA
Bought a A15 Turboed from a friend which he had in his UTE for two year. It is fitted with E15T (Exa Turbo) pistons. Boost 1 Bar with KKK Turbo from some VW. When i picked this motor up it was stil running good. Now it is patient for my resto to get done.
Posted on: 2009/1/9 13:53
From South Africa
well I Have had good luck with mine, Also running Langley dome pistons and 40thu chopped rods, with 2 head-gaskets.... bin boosting 14psi into it ever since day 1 and I'm going on 3.5 years now, not a single problem from it. just make sure you torque the head properly, and do at least 2 re-torques with about a weeks interval while you are running the motor in...
Posted on: 2009/1/9 14:03
From South Africa
MY motor is standard,but i think first of all i must get a boost gauge and regulator
Posted on: 2009/1/9 14:16
From South Africa
What gasket did you used ?
Posted on: 2009/1/10 10:32
