oil queries
From campbelltown (sydney) australia
with the hose on the top of the rocker cover, that runs into ur inlet/ air filter, is it bad if u r finding amounts of oil inside the filter?
Posted on: 2003/7/16 12:54
Re: oil queries
From durban, south africa
hey bud,
what is your motor like? it could be worn piston rings or you have overfilled your oil.
i know on my old mans car he was using oil like hell and kept filling the air box, turned out worn rings.
hope it helped
cheers
nicholas
Posted on: 2003/7/16 13:10
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: oil queries
yeah it did i dunno whether its worn or overfilled but it only gets oil up when i rev it real hard hehe i do it all the tim so i dunno maybe its just coz the engine is revving real hard its throwing oil into the filter
Posted on: 2003/7/16 13:53
Re: oil queries
This pipe transfers filtered air into the engine to replace the crankcase fumes drawn out by the PCV system.
If you have a blocked or faulty PCV valve you will have a situation where the crankcase pressure will push the crankcase gasses, with oil in suspension, back up this pipe. Check the PCV valve & system first.
If this is OK, then i got bad news for you.
Chris
Posted on: 2003/7/16 14:09
Love your Datsun.
Treat it well.
Re: oil queries
do dattos have a pcv valve on the rocker cover? i know my chev does i havent seen one on mine but it just has a hose that goes from the rocker cover to the air filter
Posted on: 2003/7/16 15:06
Re: oil queries
From Fort Worth, Texas, USA
Nyet! The PCV hose comes from the crankcase under/behind the exhaust manifold and runs to a screw in PCV valve under the carburetor on the intake manifold. I can't remember if it is on the engine side or the fender side though. I think it is fender side on an A-series. Does that make sense? I'm trying to describe which side of the plenum below the carb it screws into.
Posted on: 2003/7/16 16:49
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
Re: oil queries
From Wanganui, New Zealand
There can be a problem with oil spilling out through the breather on the block when cornering hard on RT hand corners. It is a problem to overcome because it is caused simply by the oil swirling up the inside of the block under hard cornering. However a good "catch tank" type arrangement in the breather line will fix the problem.
Posted on: 2003/7/16 19:46
