wheels
Not too shy to talk
From tas
hey people... can i fit 16x6.5's on a datsun ute??
Posted on: 2009/1/16 6:08
Re: wheels
From Adelaide, Australia
You'll need to tell us what struts/brakes it has and what the offset/backspace of the wheel is?
Posted on: 2009/1/16 6:13
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: wheels
Not too shy to talk
From tas
its a 1985 1200 ute all standard struts & brakes i think the wheels are a 40 or 45 offset but i was thinkin i could use bolt on spacers ... i was told 16x7's would hit on the gtouard wen i turn... all i did b4 the respray was roll the lips up..
Posted on: 2009/1/16 6:28
Re: wheels
Not too shy to talk
From tas
pls help
lol
Posted on: 2009/1/16 6:49
Re: wheels
Not without modifying the body. 6" wide wheels are the limit.
Well, if you narrower tires on it might fit under the fenders. Say 205/50R16 tires. And spacers, depending on the wheel offset.
Don't buy the wheels without a trial fit...
Posted on: 2009/1/16 7:02
Re: wheels
Not too shy to talk
From tas
so does that mewan 15x6.5 are out too?
thanx
Posted on: 2009/1/16 7:05
Re: wheels
Do you want a guarantee? Maybe you can fit 6.5" wide wheels, maybe you can't.
Stock ute wheels are 4" wide.
Posted on: 2009/1/16 7:12
Re: wheels
Not too shy to talk
From tas
i just cant find the wheels i want in tas very #### range and like you said dont buy without a trial fit.. just hav to keep looking i think...
Posted on: 2009/1/16 7:25
Re: wheels
It's the same here. You probably have a better selection in Tasmania.
Take a look at datsun1200.com Wheels.
Posted on: 2009/1/16 7:30
Re: wheels
From Geelong, Vic
wit a stock body there is not a chance of fitting 16x6.5s and hbeing able to turn. you cant fit 15x6s and not modify the body at all
but to make them fit at the front you just need to choose the right ride height and cut a bit of the front corner of the front guard out
with the right offset and ride height they will also fit on the back
Posted on: 2009/1/16 9:48
