« 1 (2)
Re: oil leak thats spreading?
From Adelaide, Australia
You know if you drain all the oil out it won't leak anymore...
Doesnt matter when the L goes in... will leak more.
They go quicker with a few leaks I am told.
Posted on: 2009/1/16 6:07
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
3 drops in three days? I don't call that a problem.
That reminds me of the forklift we used to have at work. When it stopped smoking the boss would yell at us "didn't you see it has stopped smoking? Put some oil in it before you ruin the engine!"
Posted on: 2009/1/16 6:29
From northern 'burbs adelaide
bahahahahahahahaha to that last post
Posted on: 2009/1/16 11:54
Well you know it is at the end of the sump.
There is a hard seal that sits on the end of the crank shaft before the flywheel.
There is also a semi-circled rubber seal that seals the sump to block EDIT: sorry, it seals the sump to the underside of the end bearing cap (securing the end of the crank that meets the flywheel) which carries the hard seal. This rubber seal may be old and what you may be getting isn't a three day leak but simply a tired seal.
Depending on how much time you have, you really ought to seal the lower end.
But it sounds like a minor leak so keep the convenience of an operating vehicle and simply observe.
Once it starts pissing out everywhere. Repair the problem and tackle all your other modification/maintenance plans.
It sounds minor, I wouldn't fret. Check your levels and fix it when it really goes wrong.
Posted on: 2009/1/16 12:23
I would also ignore the sump plug. It is a simple thread n seal arrangement. Unless it spins free or cross threads you do have an issue.
Tighten up and it seals.
Cross thread all crooked and it'll leak.
Posted on: 2009/1/16 12:25
From Oberon NSW {Bathurst}
The best tell tale to finding your illusive leak is simple, Baby Powder! Wash the sump/box everything down really well, let it dry completely then give it a good puff of baby talc. Start her up while cold in a minute you will see exactly were the oil is comming from. My guess is sump gasket around the rear main, they are a sod for leaking there. Should send a pic of mine! I get the drip tray out from under mine and pour it back in before I go for a drive!! A few drops HA! Last time I drove Betty, Mitchell to Charleville, 190klm she burnt and leaked about 1/2 a litre. You got no worries
Posted on: 2009/1/16 12:36
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
« 1 (2)
