« 1 (2)
Re: need help theres water in the oil of my a12 in my 120y.
From Schofields
Whorida wrote:
EDIT: Had the exact same symptom with my old ute. Gasket was blown between 2nd and 3rd cylinder.
and guess who he had to get to do the work for him!!??!! its all good at least i knew what i was doing!!
Posted on: 2009/1/24 10:43
its real milky on the bottom of the oil cap.
Don't bother to pull the head off. Is there water on the dipstick too?
If it is only on the bottom of the oil cap, it is a minor problem, with a different fix.
Posted on: 2009/1/26 4:55
From Bendigo, Victoria, Australia.
Yeah i'f you've done a head gasket you will have a misfire when the car is first started. a bit of "milk" on the oil cap is caused by condensation of the air in the crankcase. nothing major to worry about, if you want though, get a new cork washer to put around the oil cap. and bend the legs a bit to make it seal tight.
but still try the compression and pressure tests. you could have blown a gasket...
Posted on: 2009/1/26 7:56
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From hastings,vic
could be corosion in timing cover/water pump, coroded head??
Posted on: 2009/1/26 8:12
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
« 1 (2)
