Wheel offset troubles????
From sydney
I'm looking at buying a set of rims but i'm trying to work out if they'll fit on my ute, the whhel measurement are 13"x5.5 +38offset. can anyone help? will they fit or will they scrub out?
Posted on: 2009/1/25 7:08
Re: Wheel offset troubles????
From Brisvegas, oz
it all depends on what struts you have.
standard, stanza, 180, datsun ect ect you will need spacers if you have r31 struts i think you might get away with it and s13 struts are ok for +38
Posted on: 2009/1/25 7:53
www.camerasplus.com.au
From sydney
its a 1000 ute, its pretty standard front end that i know of.
Posted on: 2009/1/25 8:18
From newcastle, NSW
There was a link somone put up in another thread, it's a wheel offset calculator. You basically put the measurement of your old wheels and then you put the measurement of the new wheels and it'll tell you how far the wheel stick in or out of the guards.
How this helps.
Posted on: 2009/1/25 10:35
From Brisvegas, oz
clicky
then just change the page at the top
Posted on: 2009/1/25 10:40
From Darwin NT
link
you will need to run 20mm spacers forget those ####ing wheels
doh beat me too it
current project 4x4 patrol...
From sydney
i feel so stupid cause i dont know the offset of the wheels i have on the car now,
i have a set of jelly bean mags, does anyone know what the ofset is on the jellybeans?
Posted on: 2009/1/25 12:33
From Darwin NT
i went off the ofset that my mags on my 1000 are at now they fit well and there at 13mm offset probably be better at around 15 but ohwell
i went of mine and you will need a 20mm spacer for yours
Posted on: 2009/1/25 12:35
From Brisvegas, oz
i would think that they are a standard datsun ofset which is +24 at 6 inch wide
Posted on: 2009/1/25 23:39
From Darwin NT
1000s used something like a 12" wheel at 5" wide so its different to 1200's and other datsun models that used a larger wheel ill go out and measure my originals soon
Posted on: 2009/1/25 23:42
