I Need A12GX Head o anything Better for Buy
I Need A12GX Head o anything Better,
may anybody have one?
Thanks.
Posted on: 2003/7/22 0:47
Re: I Need A12GX Head o anything Better for Buy
Yes, the Nissan Competition head is better.
11041-H2302 GX CYLINDER HEAD (TO 6/73)
For use with any A-series engine built up to 6/73. It has 29cc combustion chamber, and due to its large intake port size, must be used with eitehr the GX or Mikuni/Solex intake manifold. Valve size is 35mm/1.38" (intake) and 29mm/1.14" (exhaust).
11041-H5703 GX CYLINDER HEAD (FROM 7/73)
Specifications are the same as 11041-H2302. For A-series engines built from 7/73.
99996-H1167 COMPETITION CYLINDER HEAD (TO 6/73)
This cylinder head is recommended for racing purposes only. Must be used with either the GX or Mikuni/Solex intake manifold. Competely ported, polished and fitted with competition intake (37mm/1.46") and exhaust (30mm/1.18") valves. For A-series engines built up to 6/73.
99996-H1165 COMPETITION CYLINDER HEAD (FROM 7/73)
Specifications are the same as 99996-H1167. For A-series engines built from 7/73.
None of these are currently available from Nissan. But you might find one used. Search the classifieds here for cylinder head.
Posted on: 2003/7/22 5:45
From Las Vegas USA
Where are you located????
Posted on: 2003/7/22 19:04
Thank, I'm in Dominican Republic.
Posted on: 2003/7/22 23:23
amaury, have you seen the Tech Section article A-type Cylinder Heads?
Posted on: 2003/7/25 5:17
