« 1 2 (3) 4 »
Re: wrecking 1200 coupe. adelaide
mmmmm not sure. would have to be very similar. wouldn be as strong as a ute diff but fine for an a12
Posted on: 2009/1/28 10:35
From adelaide hills
thats all im running
but it takes a bit of a hammering!!
Posted on: 2009/1/28 10:40
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
From Armidale N.S.W
Pre 74 ute had same as sedan didnt they ?
Posted on: 2009/1/28 10:41
73 1200 wagon SOLD
From Melbourne, Oz
It may be benificial if your traveling long distance as it has a taller ratio
If you were to do it you would need to cut the shok/spring seats of the ute diff and weld them tothe coupe diff and relokate the break line spliter.
Posted on: 2009/1/28 10:43
"I hav achieved wood"
From Adelaide, Australia
Just get a bluebird H165 centre and get new axle bearings...
As for the coupe rear end in your car, Shocks mount the same was as on a coupe, to the u-bolt plate, so technically you could bolt the whole coupe setup in, you'd need the tailshaft also.
Oh yeah, the brake line splitter, but you could just cable tie that.
Posted on: 2009/1/28 10:45
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
well i have the tailshaft too if your interested. i
Posted on: 2009/1/28 10:48
From adelaide hills
too much work atm with a broken hand!!!!
if i cant get a ute diff tho and you still have the parts ill let ya kno
Not too shy to talk
From Adelaide, South Australia
am after a floor rail and piece of floor for the drivers side - to suit a 75 ute would the floor rails be the same as the coupe.. if so how much $ i can cut out myself no worries
Posted on: 2009/1/30 7:20
i am guessing they are same. its a bit rusty in the drivers side foot area but your welcome to have a look. carton of beer and you can go crazy with a grinder on it.
Posted on: 2009/1/30 7:37
From pooraka,,adelaide
Hey man r the indicators the same as the 1200 ute?
Cause I think mine on my ute r from a 1200 ute and I want new ones
Posted on: 2009/1/30 7:48
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
« 1 2 (3) 4 »
