rear drums
From Brisvegas, oz
im looking at ptting the 31 rear drums on the h165 axle i have and im wondering how you get the drum completely off, i can only seem to getthe front and the internals off but not the backing part... do i have to remove the axle to get the rest off?
Posted on: 2009/1/29 7:39
www.camerasplus.com.au
Re: rear drums
From Armidale N.S.W
Yeah i reckon you would.
Posted on: 2009/1/29 7:41
73 1200 wagon SOLD
Re: rear drums
From northern 'burbs adelaide
yep remove axle and the whole lot should come off (going by corolla, gemini and datsun experience)
Posted on: 2009/1/29 7:46
Re: rear drums
From Melbourne, Oz
Yeah there is 4 bolts behinde the axle flang, there is a big hole in the flang so you can undo'em and it shoul all come out with a little persuasion.
Posted on: 2009/1/29 7:51
"I hav achieved wood"
Re: rear drums
translation: little persuasion = big hammer (or if you know the bare stokie trick)
Posted on: 2009/1/29 7:54
Re: rear drums
From Melbourne, Australia
you need a press to remove the wheel bearing before the backing plate can come off the axle
or cut the wheel bearing off with angle grinder very carefully
either way you will need new wheel bearings to go back on and probably a press to put those on as well
Posted on: 2009/1/29 8:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
