FIRING ORDER
help im looking for firing order for my L20
B.... if possible i would like to see a photo of the engine with this pattern and location of #1
Thanks
Rkarts
Posted on: 2003/7/25 21:38
Re: FIRING ORDER
From Stone Age somewhere in U.S.A.
the firing order is 1-3-4-2, #1 cyl. is obviously the most forward one. the location on the dist. cap is something else as someone may have changed the location
Posted on: 2003/7/26 1:59
Re: FIRING ORDER
If the A12 distributor was put in exactly the same as the factory, the vacuum advance is pointed at 1:00 o'clock (as if sitting in the car, with 12:00 straight ahead). #1 is on the left side (at about 2:30) and the order is counter-clockwise.
Of course, the more important thing is:
1. the crank is at 5 degrees BTDC for #1 cylinder
2. the points just opening. This is later checked with a timing light for best accuracy.
3. The rotor lines up exactly with the #1 cap tower
The distributor can be removed and reinserted to get it to line up just this way (at 1:00). But it could also be in a different position and meet all three requirements above.
Posted on: 2003/7/26 5:36
Re: FIRING ORDER
DD,
the L series uses a different setup to drive the dist. there is a spindle shaft that goes into the timing cover that is driven off the crankshaft. it turns both the oil pump, and the dist. if someone has changed the timing chain or pulled and replaced the oil pump things may not line up as they were when new.
Posted on: 2003/7/26 6:35
Re: FIRING ORDER
L20? I read it too quick, thought he was asking about Datsun 1200 firing order
Posted on: 2003/7/26 7:05
Re: FIRING ORDER
From Mandurah WA
Same firing order for any 4cyl car.
Posted on: 2003/7/30 13:24
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: FIRING ORDER
From Millgrove Vic OZ
Some early ford fours were 1, 3, 4, 2,
Others were 1, 4, 2, 3 or something similar.
Posted on: 2003/7/30 23:10
Cheers Feral
Re: FIRING ORDER
My 4-cyl car is 1-3-2-4 (subaru). Even some inline fours differ.
But I know what you mean -- most, if not all Datsun fours have the same firing order: 1-3-4-2.
Posted on: 2003/7/31 3:59
