WTB B210 trunk seals, where?
From Vancouver BC Canada
any good sources out there?
Posted on: 2009/2/10 1:37
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: WTB B210 trunk seals, where?
Nissan.
Scott's Rubber.
Posted on: 2009/2/10 4:18
I was hoping there was a generic strip you could use.
Is the factory strip interchangeable with the 1200?
Or 210 for that matter...
Posted on: 2009/2/10 6:29
Keith (Mac-Datty)
From Adelaide, Australia
Just go to nissan and ask, the parts fit right and are nearly always available.
Posted on: 2009/2/10 6:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Snohomish, WA USA
Any of your body supply shops will carry weather stripping rubber. Usually comes in a roll and you just buy what you need.
Wesco Auto Body here in Seattle sells it.
Posted on: 2009/2/10 6:38
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Nissan says it is discontinued and nothing is interchangeable.
Posted on: 2009/2/10 18:00
Keith (Mac-Datty)
From Albuquerque NM, USA
Keith,
Is it for the car in your avatar? (fastback/coupe) or is it a Sedan?
Sedan does show no longer available
part # 84810-H5000
Coupe part # 90810-H5501 shows available but shows on back order.
I have seen parts on back order take 3 months to get.
btw, that part # is for the seal on the body of the car.
Kelmo
Posted on: 2009/2/10 21:18
From Selah, Washington
I have a 210 (B310) seal in mine.
It is longer. Get a used one and try it. Mine seams to be tighter but... I have changed the the rear hatch out on mine, so it may just need adjusting.
Posted on: 2009/2/11 1:22
Nope, its for my green car.
Not my blue coupe or red coupe but my green sedan.
I found some stripping at a marine supply store for 20 bucks, I think I'll give it a shot first.
Posted on: 2009/2/11 2:40
Keith (Mac-Datty)
