s13 brakes
Quite a regular
From Brisbane
Hey just after abit of help im lookin at a set of front brakes from an sr20det s13 with 280mm rotors just wondering if they'll be right to use n what the minimum size wheel ill be able to run with that?
Posted on: 2009/2/25 21:08
Re: s13 brakes
From malta
you'll have to run a minimum wheel of 15"
the brakes will be right for the right function and power depending on what you have in mind. can u be more specific pls
Posted on: 2009/2/25 21:20
Re: s13 brakes
Quite a regular
From Brisbane
i just want better brakes for the street at the moment cant pull up for #### its got a 13b bp in it round the 200rwhp mark.... at the moment im running 17inch wheels but will be running smaller wheels in the future i think
Posted on: 2009/2/25 21:26
Re: s13 brakes
From Nyngan, nsw Australia
i think by his user name it be a 13B rotary,
i could be wrong!
Posted on: 2009/2/25 21:34
living is good,.....
Re: s13 brakes
From Wagga Wagga, NSW
g'day mate, brilliant sounding drivetrain in your ute.
Now theres a couple of things to note depending on weather you have 1200 drum struts or 120y/1200 disk struts, if you have the standard drum struts installing s13 brakes is as easy as this.
1.remove all drum assembly off the strut only to leave the hub.
2.slide s13 disk straight over the existing hub.
3.place your caliper in position on the disk and make a template for a caliper bracket, it will have to be an offset bracket as the drum strut hub is a few mm's off the caliper being exactly inline with the backing plate bolts.
4.you may or may not need a brake master cylinder from a disk strut 1200/120y but is probably better suited.
5. bleed brakes and your away!
For a disk brake strut.
1. remove standard discs and what not.
2.remove hub and get machined/file until the s13 rotor will slide over the hub and fit snug.
3.place hub disk and caliper back onto strut and make a carboard template for a caliper bracket, on the dick brake strut the caliper and mounting ears are the same offset so you are able to use a flat bracket opposed to an offset one, makes it much easier to make at home.
4.bleed brakes and your away!
Posted on: 2009/2/26 0:21
Re: s13 brakes
Quite a regular
From Brisbane
thanks for ur help mate... yeh its got the disc brake front end on it
Posted on: 2009/2/26 5:30
Re: s13 brakes
From Melbourne AUS
the 250mm s13 brakes will pull up a 1200 with a rotary in it just fine.. (thats what i have)
and you can run smaller wheels, 14's fit and even some 13's from what ive heard
Posted on: 2009/2/26 5:53
1973 B110 A12
Re: s13 brakes
From Christchurch NZ
The 250mm S13 brakes provide orgasmic stopping.
Posted on: 2009/2/26 6:45
Forced Induction!
Re: s13 brakes
Quite a regular
From Brisbane
yeh i know that the 250mm will be a massive upgrade ova stock but a set of front 280mm have come up hopefully at a good price so will go with them if all is sweet otherwise i will be lookin at the 250mm ones..... probs only lookin at havin atleast 15inch wheels on it neways
Posted on: 2009/2/26 6:56
Re: s13 brakes
Ive got a set of 280mm with lots of meat on them and calipers for sale for only $90!
Posted on: 2009/2/26 6:58
