does anyone have a pic of the wiring of the back of the insturment cluster?
Not too shy to talk
From Rockhampton QLD
hi i was wondering if anyone has a pic of the wiring in the back of the instrument cluster for a 1200 ute. mine has the clock not a tacho aswell.thanx
Posted on: 2009/2/26 2:12
Re: does anyone have a pic of the wiring of the back of the insturment cluster?
Posted on: 2009/2/26 4:13
Not too shy to talk
thanx for that ive already looked at that page but i didnt pay much attention cause that has everything i need
Posted on: 2009/2/26 4:28
So do you need a pic, or does that pic have everything you need?
Posted on: 2009/2/26 4:30
Not too shy to talk
the pic has everything i needed. but i just went and fixed that problem and then i found another wire that i dont know were it goes. but its a red wire with a male end on it and its only about 5cm long i guess give or take a lil. if you want i can send u a email with the pic and ill mark were it comes out? i dunno how to put pics up on here
Posted on: 2009/2/26 5:25
Glad to hear it helped.
Apparently there is some variation in harnesses. Some are like this:Quote:
The clock has a third wire, which goes to the Red/Black wire hanging down from the harness.
You can email a photo to me and I'll post it and comment on it.
Posted on: 2009/2/26 5:42
Not too shy to talk
ritio then i just emailed you with it then and marked were it comes out
Posted on: 2009/2/26 5:58
OK, It's the same pic as in the Album, just marked to show a Red wire coming out of top center of instrument cluster.
See
Wiring - Ute Amplifier Speed Switch
If your ute is missing the Switch, no worries. It drives OK without it, just slightly more emissions above certain speeds when decelerating.
Posted on: 2009/2/26 6:26
Not too shy to talk
ok then thanx for that
Posted on: 2009/2/26 8:42
