Starter Motor Problem ?
From Sri Lanka
Hi Guys
When i start My car ignition suddenly feel Motor starts and get stuck suddenly, and again capture may be same time or when i ignition it again
what would be the case ? Battery ? or Starter Motor ?
Thanks
Regards
Sumith
Posted on: 2009/2/26 3:07
Re: Starter Motor Problem ?
From Armidale N.S.W
start by checking and cleaning all ya terminals on battery and on starter motor. Sounds like crook solanoid on starter which just easier to replace starter.
Posted on: 2009/2/26 4:19
73 1200 wagon SOLD
Can you describe the problem? Does it make a grinding sound or a whizzing sound?
Posted on: 2009/2/26 4:27
From Sri Lanka
Hi ddgonzal
It is a whizzing sound, with whizzing sound motor get start then suddenly get stuck, then if i keep ignition key it will start it again, or else i have to start the ignition again ,feel motor starts hardly any Idea Pls
Thanks
Regards
sumith
Posted on: 2009/2/26 6:33
Classic symptom. It means the pinion drive gear clutch (overrun clutch) is bad.
You can easily replace the starter gear (which is sometimes called a "Bendix gear"), they are about 1/4 to 1/2 price of a starter.
See Open in new window
Starter - service
Posted on: 2009/2/26 6:51
