f.s.:A15 complete motor with 5speed celica box
Not too shy to talk
hey
im selling my motor out of my 1200 ute
becasue im doing a 2litre conversion
the motor is a A15
with:
-webber
-extractors
-celica 5 speed box
-exaust if needed
-motor is in good condition
i think it has a couple other things just
cant think of them.
selling as complete motor will not seperate
also you can have what ever you need to do with the motor like raditator etc
looking for $1500 and im located in brisbane/ goldcoast
http://i243.photobucket.com/albums/ff ... rickey_trent/100_1398.jpg
Posted on: 2009/2/25 10:04
Re: f.s.:A15 complete motor with 5speed celica box
From Armidale N.S.W
What 2 litre conversion you doin ? I'm soon to be sellin an SR20 with wiring loom ECU and MadDat cross member Might sell the 5 speed box with it to.
Posted on: 2009/2/25 10:11
73 1200 wagon SOLD
Not too shy to talk
a worked l20b
Posted on: 2009/2/25 10:18
From Armidale N.S.W
you will need to put all the EGR(polution gear) stuff on it if your going to engineer it as L20b didnt come out in a pre polution vehicle. Then the question is will it run with all that if its heavily worked ? Anyway could all be irrelevant as you may have done all the research. L18 and L16 are easier there a shorter block (height) and give you more bonnet clearance especially with a 200b or bluebird sump and oil pickup. Trust me im doin one and have L16 in the car waiting for a sump etc to get it lower and make mounts.
Posted on: 2009/2/25 10:25
73 1200 wagon SOLD
L18 is a better bet for pollution and overall weight
A combo hard to beat is.....
L14 rods for perfect 1.751 rod/stroke ratio
89mm sleeved bores for 1941cc and the option
of running a Pro-swirl 3 valve Ka24E head.
ka24e pistons with 2mm shaved off for good deck clearance.
The sleeving is trivial most engine and repco places can do it.
L14 rods can be had from specialist datsun joints or ordered
from overseas.
A better option is to use local cheap and beefier e15et rods but need crankpins machined (175aud got quoted from repco) to 40mm meaning more power/less friction.
costs
Sleeved block for 89mm 350-400
Crankpins machined for e15et rods 175
Re-balancing crank and retreating crankpins 250
Ka24E pistons and head around $80 from Pick-a-part
(tear an e15et apart and put the rods in the sump for freebies)
L18 bottom end $60 from most wreckers.
Z20e timing front cover, chain and tensioner bits can be taken with L18 block.
KA24e turbo conversion on L20 block
When money allows you get one of the 2 inlet valves on the ka24e head (the one facing the sparkplug) resized to 35mm or 1mm over to decrease exhaust overlap and have a bias of increased flow towards the sparkplug area of the chamber.
This would be my engine choice for a datsun 1200 if I ever decide to own one. LPG would be the juice of choice.
Posted on: 2009/2/25 11:22
Not too shy to talk
thanks for that i can see what you mean ill have a think about it
There is also a picture now the link is down the bottom
Posted on: 2009/2/25 20:16
From Gold Coast QLD
Hi, Have sent a message but not sure if I did it right...I'm on the Gold Coast and would like to talk to you about buying the A15 and box. Contact please on 0423 967 730
Posted on: 2009/2/26 10:45
Contact 0423 967 730
Not too shy to talk
yer mate got it
Posted on: 2009/2/27 2:25
From SA
hey mate
just wonderin where you are, as i am interested in the 1500 and box :)
cheers Daniel
Posted on: 2009/2/27 6:20
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
If you read the post it says where he is.
Might not be worth the freight for an Adelaide lad?
Nice setup though.
Posted on: 2009/2/27 7:11
