« 1 (2)
Re: Does anyone want something made?
From Ballarat Victoria
Revhead and Clyons, you have Pm`s
If anyone wants manifolds made for bike carbs or throttle bodies, you will have to either send me them so i can make a manifold to suit or you`ll have to send me detailed drawings. I have a standard 1200 i can use for body clearance issues, but will need all other dimensions.
If a few people want them made and can settle on a particular common Quad carb (or throttle body setup). This would make life easier for me and cheaper for you.
Something like the one shown in the earlier pic is fairly straight forward.
It would involve matching the carb outlet diameter with tubing and tapering it down to match the oval port and tig welding these to precut flanges. Be aware that a design like this has some compromises where the the runner angle meets the port and the carb, but would be cost effective to make. Id guess about $230.
As for scuff plates, i`ll have to do some homework. I`ll get back to you all.
Posted on: 2009/3/6 11:14
VIC DYNO HIRE
The strut top covers i will have to look into also. They would have to have an "O" ring or similar to hold them in place. More homework required!!
I know polished ally would be easier to make.
Posted on: 2009/3/6 11:32
VIC DYNO HIRE
I made these for Clyons Dat1000 as requested. (you should receive them by tues Chris) Open in new window
Posted on: 2009/3/28 12:07
VIC DYNO HIRE
From Perth WA AUS
Can you make my wife into a total hornbag?
Posted on: 2009/3/28 12:37
Datsun 1200 2Dr sedan.
From Perth
That shouldn't be too difficult
You have a good base platform to work off
Posted on: 2009/3/28 16:25
From canberra
can you make Traction Bars to sute 1200 with skyline diff
Posted on: 2009/3/28 21:54
need to move your ride
tuggeranong towing call 0421towing
0421869464
From Tamworth , NSW
have you got a larger pic of that manifold sikyne?
Posted on: 2009/3/28 21:56
Steve that's as big as the pictures get.
If you PM me your email I can send you bigger ones.
Posted on: 2009/3/28 23:19
From Tamworth , NSW
that pic is fine mate, bit bigger than the others.
that looks like a nice bit of gear.
let us know how you get on with them.
Posted on: 2009/3/28 23:25
Yfj20t,
I would either need the car or at least need to know if your using the original spring locations and if it is a ute or coupe as the front spring location is different. There are also several ways to go about it.
Eg. chromolly tube w chromolly threaded tube adaptors to screw rod ends into.
Or mild tube with urethane bushes at each end.
The front location can also be done in several ways.
Send me a PM if you are serious, to talk about options/ costs.
Simon.
Posted on: 2009/3/29 2:57
VIC DYNO HIRE
« 1 (2)
