Gearbox not too happy
From adelaide hills
aight
in 1st there is a clucking/ticking noise
2nd its not as loud
3rd,4th cant hear it
any ideas what is wrong
i reckon the rubber in the mount is busted
plz help!!!
Posted on: 2009/3/12 11:28
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: Gearbox not too happy
Could be the mount. Place jack under transmission, remove mount and inspect it.
Posted on: 2009/3/13 3:09
From gold coast QLD.
Or a chipped tooth,i've done it before,after you check the mount,drain the gear oil,if there is any metal floating around it will be stuck to the magnetic drain plug and all will be revealed.
Posted on: 2009/3/13 6:08
From adelaide hills
i will give the mount a check
ithiink thats wat it is wen i busted my engine mouts i check it and it looked pretty brittle
Posted on: 2009/3/13 9:21
From Charlevoix, MI USA
Hopefully this sound is from an external source of your tranmission. While you are there, make a good inspection of your drive shaft,especially if the sound appears to come under initial load (i.e. first gear) .
Posted on: 2009/3/13 22:29
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From adelaide hills
got a mechanic to sus it out
and he reckons a counter gear has busted a tooth
and recomends buying a new box instead of repairing this 1
Cheers
Posted on: 2009/3/14 7:00
From adelaide hills
well its buggered
first is floating around in the bottom
2nd and 3rd work tho
time for a new 1
Posted on: 2009/3/15 8:29
