Browsing this Thread:   4 Anonymous Users
Fixing Voltage Meter
From Sri Lanka
Hi Guys,
I have a voltage meter , i want to fix it and see it is working , can any one help me to fix it to the alternator through voltage regulator , and way to check whether it is working or not before fixing it
Please
Thanks
Regards
Sumith
Posted on: 2009/3/13 6:00
Re: Fixing Voltage Meter
What kind of voltage meter? In general, they have two wires, one goes to earth, the other to "Hot".
Posted on: 2009/3/13 6:07
From Sri Lanka
Hi ddgonzal
It is a round gauge(just like a wrist watch with red color indicator), that is all i know about it,i have seen those type of meter in racing cars , hot means (Power line-possitive) ?
Thanks
Regards
Sumith
Posted on: 2009/3/13 6:21
From Sri Lanka
Hi ddgonzal
and also there is same type of Oil Pressure indicator also next to that , want to fix that also
Thanks
Regards
Sumith
Posted on: 2009/3/13 6:28
Re: Fixing Oil Presure Meter
From Sri Lanka
Hi Guys,
Please let me know how the Oil Pressure Meter is connected , how will be the wiring connection
if i connect oil pressure sensor and meter directly will it work or does it need another voltage line
thanks
Regards
sumith
Posted on: 2009/3/16 8:42
Unknown. Datsun B210 did not have an oil pressure gauge. Different kinds have different instructions.
Posted on: 2009/3/17 3:25
From Sri Lanka
Hi ddgonzal
Look at this picture,
http://datsun1200.com/modules/myalbum/photo.php?lid=19241
Here you see 2 small meters at the left , those are ampere meter and fuel pressure meter, i am referring to those, how to fix them
Thanks
Reagrds
Sumith
Posted on: 2009/3/17 5:32
I'm sorry I do not know.
Posted on: 2009/3/17 5:50
From adelaide hills
ive got both these gauges
the volt meter should have 1 wire as an earth and the other 1 will be positive. connect the positive to the on wire that runs to the ignition and the other to earth
for a mechanical oil pressure u will need a small plastic line that runs from the guage to above the oil filter. i replaced the oil light sensor with the guage.
Posted on: 2009/3/17 9:55
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
From Sri Lanka
hi 77datoute
Is Oil Pressure also need a earth and also the other connector to the Fuel sensor at the fuel filter
or just a single line ?
Thanks
Regards
Sumith
Posted on: 2009/3/17 10:39
