i have the coolest idea!! well i think so
From ipswich
im pulling my a12 turbo out on my ute. as its not running and im planing to put a different motor in i still want to play around( find out why it not working riight) with this motor as i have put much time ito it and money so im making up an engine stand that i can have the engine running on similar to it being in a car but being much easier to work on and i want to mave all the guages. i also want to make it so that i can have some load on the engine so i can test it so its not free reving but im not to sure hom im gonna do that. there was an engine at tafe i went to a few years ago that was on an engine dyno and it had all the bit like guages, throtlle and all that stuff on like a control panel and that what im attempting to make but much smaller and of course i dont have the dyno
this might be a waist of time and money but hey its something to do
Posted on: 2009/3/13 6:53
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: i have the coolest idea!! well i think so
Sounds like a fun project.
Putting a load on it is called a 'brake'. Not sure how you'd do that.
Posted on: 2009/3/13 7:09
From Melbourne vic
what you need is an electromagnetic
"retarder" or "brake" off a bus or small
truck, they have variable load. And of
coarse you need 3 phase power to run it.
Posted on: 2009/3/13 7:13
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From ipswich
i was lookin at some sort of electric motor but unsure how id go about making it work. i want to have the gear box attached as it would probably make it easier to attach something. i no with some ehgine dynos they use a water brake of some discription. my idea was using a propella in a water tank as a load. how ever they use weight and add it on at a certain rpm to find the given tourque and from that can calculate the hp. i have a whole bunch of formula and info from when i was at tafe that i quite usefull i just have to dig it up. im not sure if it is goin to be possible but i would like to create some sort of dyno that i can get some kind or reading as to load im putting onto it
im very keen to get started on this project. i no my biggest issue with my motor not running is the carby but since its not goin to be in the car i have my options as to gettin a different carby on it as room is not an issue. i will most like post up pics of my progress as it will be somewhat interesting
Posted on: 2009/3/13 7:25
datsun 1200 ute
From ipswich
i have 3 phase power in my garage :)
Posted on: 2009/3/13 7:26
datsun 1200 ute
From Melbourne vic
what i'm referring to is a auto trans dyno
which was originally built for the tafe's.
they had a holden 202 on the front
(i think the original was a 161) and you
could adapt all soughts of trans to it and load
it to simulate driving. Of course you already
have the engine/trans combo and need the
brake.
Posted on: 2009/3/13 7:49
:Nice
From perth
big genset?
are you good with electrics?
simpler way would be a large brake disc or drum with a master cylinder with a screw in plunger to wind up the load
dont forget to make a scattershield to go around it....just in case
Posted on: 2009/3/14 3:26
From Ballarat Victoria
The cheapest i can think of that would be adjustable would be a hydraulic brake. Using a hydraulic pto pump pumping oil through a gate valve and back to a tank. if you run a load cell off the pto pump you can calculate torque and Hp.
Posted on: 2009/3/14 3:35
VIC DYNO HIRE
From ipswich
updating my progress. engine is ready to be pulled out. just not sure if my dump pipe has to come off butt ill jus pull it off any way and i have to take the tail shaft off and depending weather id be better off removing the gearbox. but i also have to chase up an engine crane
with the dist break or drum brake idea the only downside with it would be that it wont be consistant due to brake fade
if anyone could draw up some diagrams of how it could work that would be great
Posted on: 2009/3/15 4:25
datsun 1200 ute
From ipswich
makin my engine stand tomoro. i have a bunch of steel now, bit of a story behind that one lol.
Posted on: 2009/3/16 10:24
datsun 1200 ute
