Loss Power when Revving
From Selangor, Malaysia
Hi guys,
I'm installing a Twin DCOE 40s at my A14 stock,the problem after installing it, i cant rev it more than 4-5k rpm (the engine loss power) :( .
What is the main problem?And how to solve this?
Advice me please
Thanks in advance.
Posted on: 2009/3/22 5:43
Re: Loss Power when Revving
Common causes:
* partially plugged fuel filter
* bad/worn valve springs
* Incorrect engine timing
* partially blocked air filters
Posted on: 2009/3/22 7:09
From South Africa
What jets & Chokes are you running? badly jetted 40's = no power.
Posted on: 2009/3/22 10:47
From SA
yer im not sure if you have them jetted to your engine but that probs a good start, trial and error pretty much is you best opotion cheers
Posted on: 2009/3/22 11:17
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
thanks guys,
ddgonzal:i've checked the valve springs and the engine timing..it was ok ,and i ran the carbies w/out airfilters..plugged fuel filter maybe one of the factor..thanks
Rezlo:i'm not sure about the jetting bcoz this carbies is taken out from alfetta 1.6l engine (i've never jetted it)..so probably the jetting is the mainly cause?how to calculate the best jetting for this stock a14?
Gylezy: i've trial and error and playing with the mixture screw and the distributor but the same thing is still happening especially when i try to run the engine in 1st gear..
it is totally ok when idling but worst when i want to drive it..
cheers.
Posted on: 2009/3/22 12:40
From SA
hey
my twin 40 webers are form an alfetta aswell
i have them on a worked a15, flat top pistons, chunky cam and so on....
maybe take the car to your local carb shop and see what they recommend ? =}
cheers
Posted on: 2009/3/22 23:12
Go Hard Or Go Home
