indentifying 120y diff
From illawarra, nsw australia
hello all
i just need to know what diff came standard in a 1977 120y sedan
its pretty urgent
the brake specialist told me it could be either a borg warner or a japanese diff
thanks in advance
Jason
Posted on: 2009/4/2 23:59
Re: indentifying 120y diff
From gold coast QLD.
Easy as,i assume you have the car there.Look underneath at the diff,if it has a plate on the back of the centre housing its a borg warner,if it has no plate and bolts in from the front(tail shaft end)it's a jap diff.
Posted on: 2009/4/3 0:29
thanks alot mate
nearly 100% sure its a borg warner
im going to the wreckers soonish so ill remember what it looks like
Cheers
Posted on: 2009/4/3 0:45
Yes, if I recall correctly it was said that 120Y sedans were assembled in Australia and so used aussie-made BW diffs, while coupes were assembled in Japan.
BW 68, has bolts on back of the diff center section
Hitachi diff: bolt are on front of center section
More details and full-size pics: Borg Warner Diff
Posted on: 2009/4/3 4:18
yes it turned out mine was a borg warner
went to the wreckers and picked up another diff
there was about 3 wagons and they all had the japp diff
2 of these were 4 speed manual
im thinking about taking one of the gearboxes for my 120y sedan
are the 120y sedan and wagon gearboxes the same?
thanks again for the help
Jason
Posted on: 2009/4/3 10:27
Yes, gearboxes are same sedan/wagon/coupe/ute. 120Y and 1200 and Sunny gearboxes are the same
Posted on: 2009/4/3 19:10
