Wiring help needed!!
From Lisboa-Portugal
Can someone tell me if we can use the datsun coil? I didn`t understand the wiring yet.
Posted on: 2009/4/6 14:49
Re: Wiring help needed!!
Yes, you can use the Datsun coil.
There are three wires coming out of the distributor:
1. Green wire - connect to IGN - (for example, hot side of ballast resistor
2. White wire - connect to minus(-) side of coil
3. Black wire - ground/earth. Connect to engine bolt.
What is the part numbers on the Distributor?
Posted on: 2009/4/7 5:39
Hi dd sorry for the late reply but yesterday i couldn`t post anything don`t know why! I still didn`t understand very well how i`m going to make the wiring, can someone make a drawing of the connection? Regarding the number on the distributor i can`t tell you what is the number because it got a lot of numbers in the side can you tell me wich one is?
Posted on: 2009/4/9 10:01
Write down all the numbers and post them here.
If it is Ford, the main number starts with an E for 1980s parts, or an F for 1990s parts.
Posted on: 2009/4/9 22:55
I will put exactly what is on the side of the dizzy:
JGFFUX4->
0 237 601 013
87BF 12 100-HA
Posted on: 2009/4/13 11:43
Thank you. Those numbers are from the electronic module. Are there any numbers or a Hitachi or Mitsubishi symbol on the distributor body? like this?
Ford Fiesta 1.1 Distributor
Posted on: 2009/4/14 4:00
here`s the pics of all the numbers in the side:
jpg  MVC-004F.JPG (61.09 KB)
8539_49e44e8f9f6b6.jpg 640X480 px
jpg  MVC-003F.JPG (61.97 KB)
8539_49e44ed417296.jpg 640X480 px
jpg  MVC-002F.JPG (32.73 KB)
8539_49e4501f6f442.jpg 640X480 px
Posted on: 2009/4/14 9:58
UPDATE: That is a Bosch JGFFUX4 distributor (of the type '0 237 601 013')
It looks visually similar to an MG/Austin distributor which also fits in a Datsun A-series engine
Posted on: 2018/9/16 0:00
