Re: rack and pinion steering in 1200 ute
From malta
yep connor. i realized after that it only cost 29 dollars so we decided to buy it even for the initial thing we will have a virtual idea on what is going to happen. we already have the caster camber tool and it helps alot. but i am trying to keep with all the geometry thing.
Posted on: 2009/4/11 8:36
From windsor, sydney
Hi all i have some more info that has come up latley , im on to rack number 4 a holden barina power steer rack , it is the closest one to the right length of all the ones ive found , still has to be shortened but i dont have to remake the rack shaft so i modified the rest of it in a day and am now mounting it to the crossmember, it has a slightly slower ratio than the mazda one i mentioned earlier but by only 5mm per rev leaving 45mm of travel per rev this means 2.5 turns lock to lock , plenty good enough.
Posted on: 2009/4/19 0:54
hey mate
keen to know what make and year model of barina this rack came from
Posted on: 2009/4/19 1:45
finally gettin the ca18 ute project underway
Sunny’s were made to be drifted, it says so in the factory service manual: Service after every drift day and mountain tounge or 100,000km’s
it came from a 92 barina "swing" model
Posted on: 2009/4/19 2:15
1988-1994 Barina is a Suzuki Cultus/Chevy Metro variant.
Hmmm... should be easy to find these racks.
Can't wait to hear what you find about using this in a 1200.
Posted on: 2009/4/20 1:31
hi dd actualy in australia the barinas are rebadged opel's from europe
Posted on: 2009/4/23 10:06
From Tamworth , NSW
maybe only in the recent models wards, the earlier ones like the 92 model is just a rebadged suzuki.
Posted on: 2009/4/23 12:06
From The garage, NZ
^Thats an AE86 rack and pinion setup with AE86 struts and brakes etc
more: http://beeoneoneoh.wordpress.com/2009 ... 3/expression-sunny-truck/
Posted on: 2009/4/23 13:11
yes pepper you are right i will have to check the year model of my donor car but im sure it was a opel variant.
Posted on: 2009/4/25 0:06
and cheater 5 what bump steer numbers does this setup give? it looks very close to neutral
Posted on: 2009/4/25 0:12
« 1 2 (3) 4 »
