help with repairing front floor section
From Adelaide, Australia
hey guys the front floor on both sides of my 1200 is rusted preety bad. are there any rust replacment sections i can buy? if not what thickness of metal should i buy if im fabricating one up? im lucky my rails are intact and in good nick. thanx
Posted on: 2009/4/28 7:06
Re: help with repairing front floor section
From northern 'burbs adelaide
i did mine the other day in some 1.2mm and i would strongly recommend getting some 1mm bright stuff coz its easier to weld. im unsure about floor sections but for a couple of bucks 1mm bright steel is the way to go in my opinion
Posted on: 2009/4/28 9:48
Zinc Anneal is the way to go. Easy to weld and paint and won't rust in the mean time.
1 to 1.2 mm depending on the size of the patch, give yourself a minimum 1/2 inch overlap whereever possible.
Marty
Posted on: 2009/4/28 10:57
