Dash Board Lights Help
From Sri Lanka
Hi Guys
None of my Dash Board Lights are working, but my head lights signals, Water Temp Meter and Fuel sensor all work , what would be the reason. is there separate fuse for Dash Board Lights ? if so what else should not be working with that ?
help Please
Thanks
Regards
Sumith
Posted on: 2009/4/20 6:58
Re: Dash Board Lights Help
Yes, there is a separate fuse for headlights and dash (meters, etc).
Fuse Box
Posted on: 2009/4/20 7:09
From Sri Lanka
Hi ddgonzal
Is it Left Side Meter Reverse Regulator Fuse ?
Thanks
Regards
Sumith
Posted on: 2009/4/20 7:15
Yes, for a Datsun B110. I don't know what a B210 fuse box looks like.
Posted on: 2009/4/20 7:43
From Sri Lanka
Hi Guys,
I don't have any blown fuse, only my High Beam bulb in the Dash board is working now , i checked the dash board power socket, when i switch the lights on it is getting 12V Current to it ,How many 12 V lines it has to take in ? is it only one or more than that ? if it is only 1 definitely mine dash board is getting power but will not on my Lights on dash,
Thanks
Regards
Sumith
Posted on: 2009/5/4 6:30
Is the instrument panel grounded (earth)?
If you have ever removed it, the grounding screw may have gotten loose and fallen out.
Posted on: 2009/5/4 6:52
From Sri Lanka
Hi ddgonzal
If it is broken or removed , can High beam work ?
i did not see any different earth ground is it grounded to car body it self ? or should have different ground earth,or the Connector that comes to dash it self has a earth ?
Thanks
Regards
sumith
Posted on: 2009/5/4 7:05
Yes, headlights are grounded elsewhere.
The instrument panel of a B110 is grounded (earthed) by the bottom screw clip. Easy to miss. To test, just bolt a wire from metal body of the instrument cluster to shiny metal part of dash. If the dash lights start working correctly, you will know a missing earth connection is the reason.
Posted on: 2009/5/4 7:15
From Sri Lanka
Hi ddgonzal
Not the Head Light I am reffering about the small indicator bulb(dark Blue) in the Dash Board, that glow when you swith on your head light High Beam
Thanks
Regards
sumith
Posted on: 2009/5/4 7:43
From Perth WA AUS
Check that your rear tail lights (park lights) are working.
It's kind of a standard warning feature on many Jap cars to let you know your tail lights have a problem and don't work.
Might not be the case here,a bad earth connection can do some strange things! but worth a check.
Posted on: 2009/5/4 10:42
Datsun 1200 2Dr sedan.
