Blower Setup ?
From Sri Lanka
Hi Guys,
Can You guys tell me how to make my Car blower work ? I have the Ac Unit also ,but does not have working ac compressor,just help me to make my Blower at least by the moment please and also explain me how it works,
Thanks
Regards
sumith
Posted on: 2009/5/4 6:59
Edited by Sumith on 2009/5/4 7:51:22
Re: Blower Setup ?
On High Speed, 12V goes to the heater fan motor.
On Low Speed, 12V goes through resistor to fan motor.
If it works on High, but not on Low, the resistor is probably burned out. The Resistor is at right side of heater box beside fan motor. It's on the round part of the housing, you can see it up under the dash. In the center of the round is wires for fan motor. In front of that is wires for the Resistor.
Posted on: 2009/5/4 7:12
Re: Blower Setup ?
From Sri Lanka
Hi ddgonzal
so from where it is getting 12V ,before that ill have to setup the water circulation process isn't it ? i have removed water line that goes to the Ac unit,if you got some pictures please post
thanks
Regards
sumith
Posted on: 2009/5/4 7:50
Re: Blower Setup ?
12V comes from the battery, through the fusible link, and through the fuse box. By the way, you do not need the water setup. The fan can run even on cold.
I have no pictures of B210.
Posted on: 2009/5/4 17:16
Re: Blower Setup ?
From Sri Lanka
Hi Guys
How to switch On the Blower is it by the AC unit or does it have separate switch for it ? i don't see any switch in mine
Thanks
Regards
Sumith
Posted on: 2009/5/6 9:31
Re: Blower Setup ?
For B110, pull heater level out to turn on fan.
I think it is same for B210. This is the lever that moved left/right from Blue to Red. Pull out to turn on fan blower motor.
Posted on: 2009/5/7 2:57
