front 1/4 windows and door locks
From Brisbane
hey fellas how do i make my 1/4 windows stay open? whenever i got over 40 they slam shut? and also my drivers side door wont lock i cant even push down the mechanism how do i fix that? anywhere in brissy they could do it?
thanks in advance Tongy
Posted on: 2009/4/27 12:30
Re: front 1/4 windows and door locks
From Mandurah, Western Australia
Both worth checking out before you take it somewhere. But you will need to take the door card off on the inside of the door. Remove handle, window winder, lock pin etc.
The 1/4 windows have a spring and nut on the bottom of the shaft that it pivots on. This is on the inside of the door. Try winding some more tension on the spring by tightening the nut a little. It may even be damaged or missing.
The lock will mallfunction if the mechanism is stiff or out of adjustment. This mechanism is easily seen inside the door. So try operating it with the door card off so you can see whats happening.
Posted on: 2009/4/27 13:06
From Brisbane
i have tried to fix it when my handle broke the first day i got it lol. i went to open the door but it wasnt unlocked properly and i keep trying and it just snapped on the inside. it would lock but not with the key so i tried to fix it but i made it worse.
Posted on: 2009/4/27 13:29
From Brisbane
any more ideas??? really want my door to lock
Posted on: 2009/5/4 23:37
Look the door from inside. Then exit via the other door and lock it with the key.
To fix it right, you need to replace the part that broke off!
Posted on: 2009/5/5 3:18
From Brisbane
the door doesnt lock at all. cant lock it from the inside. i'd like to replace the part that broke but i dont know which part that is.
Posted on: 2009/5/5 6:20
Here are more ideas:
* Take the door panel off an pull/push on the lock linkage until it locks. Then only use the other door.
* Replace the whole door with another one
* Take it to a mechanic for repair
* Get a Datsun1200 club member in your are to come over for a six-pack after they fix it for you
Posted on: 2009/5/5 6:32
From Brisbane
well is there any fellas around everton hills area that could do it? for a 6 pack of there choice =]
Posted on: 2009/5/5 6:37
