« 1 (2)
Re: offset
Quite a regular
From Queanbeyan NSW
nah it has disc front end and drums rear
nah i cant find a link at the moment
i have a Catalogue
Posted on: 2009/5/11 11:47
Re: offset
Quite a regular
From Queanbeyan NSW
just found a web link but the offset is different.
the offset said 20-40 in the catalogue but on
the web site the offset is 15-40.
so i am guessing they wont if if the offset is
15-40.
http://images.google.com.au/imgres?im ... ENAU299%26sa%3DN%26um%3D1
Posted on: 2009/5/11 12:06
Re: offset
From Adelaide, Australia
What sort of disc front end is in it?
They are new wheels so your ordering whatever offset you like between +15 and +40
Posted on: 2009/5/11 12:09
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: offset
From Ipswich
I have 15 x 6.5 with a back spacing of + 21 and they just fit under the guards. The guards will need to be rolled and with 195 tires on they will fit. Thats if your using the silvia break up grade on a 1200 disk strut and moved top hats. So if u dont have the floating disc, u will need a back spacing of + 26.
Trent
Posted on: 2009/5/11 12:12
Re: offset
What will fit stock Datsun 1200 sedan? 12x4JJ with 30mm offset.
Posted on: 2009/5/11 19:27
Re: offset
From Ipswich
15 x 6,5 + 21
15 x 6 + 26
This sounld be right using standed front end
The easyest way is take a strut to the wheel shop, with all the breaks and hub on it, and test the rim before u order them in
Posted on: 2009/5/12 12:55
Re: offset
From Geelong, Vic
15x6 +20-25 is about r30 or trx wheel specs. which wont fit stock struts
Posted on: 2009/5/12 13:00
Re: offset
Lots of information here: Tech wiki: Wheels for Datsun 1200
Posted on: 2009/5/12 21:49
« 1 (2)
