ignition switch
Not too shy to talk
im not sure what its technically called but my key slot is jammed in the off position making the car impossible to start. i cant figure out how to get the cavity out to replace. it can anyone help?
Posted on: 2009/5/14 18:04
Re: ignition switch
From pooraka,,adelaide
wot car is it?
is it part of ur steering lock?
just pullthe clip out and join the wires in it to start
Posted on: 2009/5/15 2:17
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: ignition switch
Cylinder Lock
If you steering wheel still turns, you can simply unscrew the ignition switch (from the back of the Lock Cylinder) and turn it with a screw driver:
Ignition Switch
Posted on: 2009/5/15 4:21
Re: ignition switch
From Armidale N.S.W
Also try gently sliding the key out or in as your trying to turn it Works for me my stanza ignition jams occasionally.
Posted on: 2009/5/15 4:55
73 1200 wagon SOLD
