efi
Quite a regular
any efi units fit to a14 heads without to much messn around
cheers
Posted on: 2009/5/16 3:21
Re: efi
Yep:
* $1500-$2500 ITB setup for A14 Weber DCOE manifold
or
* Nissan A14E factory EFI manifold
Nothing else comes to mind that doesn't involve messing around.
Tech wiki: EFI
Posted on: 2009/5/16 4:39
Re: efi
From South Africa
there are a couple of people that builds A14 EFI's as well... :)
Posted on: 2009/5/16 5:03
Re: efi
Quite a regular
cool any info on those guys
cheers
Posted on: 2009/5/16 13:15
Re: efi
From newcastle, NSW
EFI hardware does some awesome efi set-ups, a couple of fellow members have them, but they'll set you back a couple of grand but they are well worth it!
Posted on: 2009/5/16 18:05
Re: efi
Quite a regular
cheers stevo
i have a nis pulsar 87 with efi sitn out the back was thinkn cuttn off the plenum n throttle body and using it some how but hey i could be totally goen the wrong way have you heard or seen anyone makn there own stuff and it actually workn?
thanks again
Posted on: 2009/5/16 21:05
Re: efi
Yes that should work. Just use all the Nissan parts, wiring harness and ECU box, all the sensors, etc. Should run OK.
The Datsun Silvia S110 setup has been used on all kinds of Datsun four-cylinder engines.
Posted on: 2009/5/17 6:02
Re: efi
Not too shy to talk
From Craigmore, SA
You shouldnt have any problems using the complete Nissan EFI setup, hardest part is making a manifold, but thats not to hard, we used a standard datsun inlet manifold and cut and shut that to suit the Nissan plenum chamber.
Ive currently got a 1600cc daihatsu charade setup on my road 1200 without any problems, We also used a Camira setup on the old sunny rally car.
Posted on: 2009/5/17 8:29
Re: efi
Quite a regular
any pictures of the cut and shut with datto manifold to nissan plenem have no probs makn this stuff but i see u can buy webber manifolds fer about 250 and then make nice lookn plenem to suit using injectors comp ra ra no probs with size throttle body ,i spose bigger better
cheers
Posted on: 2009/5/17 13:05
Re: efi
From Adelaide, Australia
if u fit the E series dizzy u can use the factory E series computer, u just have to make ur own manifold or if u turbo charge use the E15et dizzy and computer
Posted on: 2009/5/17 13:47
