Ute rear shock mounts
From Brisbane
I am just after a bit of info on the ute rear shock mounts... I am currently doing a r31 diff conversion and have had the diff shortened and redone and the guy that did the diff also made some new rear shock/ u bolt brackets up. Now he has made a few before aparently and has never had a different set. But my rear shock mounts had a thicker and longer bolt to hold the shock, are there 2 different styles of rear shock mounts? Have had the mount remade and sorted it out but the diff guy would like to know so that in the future he can know which mount to make??
Posted on: 2009/5/19 11:21
If you want more inches, stroke it
Re: Ute rear shock mounts
From Cape Town, South Africa
If the shocks does not bottom out or goes to much out on no load, I do not see a difference.
Posted on: 2009/5/19 14:27
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From Nyngan, nsw Australia
utes are 15mm, coupes & sedans are 12mm bottom shock bolts
if that helps
Posted on: 2009/5/20 3:45
living is good,.....
To be more clear: H145 utes (1971-1973) use the 12mm bolts, just like coupe. H165 utes (1974-up) use the larger bolts.
Is that right?
Posted on: 2009/5/20 3:51
From Brisbane
I thought that this was going to be the case... Ill let diff guy know that there are 2 different types of shock mount brackets
Posted on: 2009/5/20 7:56
i just used 1200 U-bolts abit longer than standard and pulled them in
Posted on: 2009/5/20 8:18
Edited by hotrocket on 2009/5/20 8:33:26
