torque
From durban, south africa
hey guys,
i have a A-12, how can i make my motor more "torquey" i've put a cam in it with a 32/36 webber, i feel i need more torque. would changing wheel dia. help?
many thanks
nicholas
south africa
Posted on: 2003/8/18 6:01
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: torque
A less-tall tire would make it feel torquier.
So would the original four-speed, which has a much shorter 1st gear than the 5-speeds.
Forced induction would help (turbo or supercharger).
Other than that, there's not much that can be done. The A12 factory setup was designed for mid-range HP. Add a bigger carb or oval port heads doesn't help with low-speed HP (aka torque).
Posted on: 2003/8/18 6:13
Re: torque
From Auckland N.Z
if you need a project you could try installing water injection, im not that keen on it myself mut a mate of mine set it up in his ####ted honda civic and it now does 3rd gear burnouts and torque steers like mad. they used it in formula 1 in the 70s with good results so i guess it cant be to bad.
Posted on: 2003/8/18 9:48
Re: torque
From Melbourne, Australia
water injection???????
cant be too hard to get an a-14 in SA, that would make your a12 a lot torquey hehehe
Posted on: 2003/8/20 10:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: torque
From Auckland N.Z
yes water injection. the cheep way to do it is run a hose to either the inlet manafold or secondary ventury. the carb will create enough suction to pull water in which will mix with the fuel and air and once ignited will create steam = torque. this will make your engine run cooler and you can advance the timing by up to 10 degrees. the only down sides are it rusts your exhorst out real quick. still it will give you a ####e load more power. If anones interested ill try to get hold of the info and test results and setup plains and scan them on for you, my mate has all the info youll need.
Posted on: 2003/8/20 13:51
Re: torque
Yes, I'm interested. With stainless exhaust it shouldn't rust too quck?
Posted on: 2003/8/20 20:50
Re: torque
yeh, so am i it's worth a try cause i have little to no torque
thanks guys
Posted on: 2003/8/21 7:01
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
Re: torque
From campbelltown (sydney) australia
with stainless exhaust it wont rust at all period as u americans say hahaha
Posted on: 2003/8/21 12:00
Re: torque
From Auckland N.Z
ill try to get the info for you next week so look out for the post.
Posted on: 2003/8/21 14:06
Re: torque
From NorCalifornia, up by Sac
period.
Posted on: 2003/8/21 17:26
