120y strtus into 1200 ute help!!!
From SA
Ok so i have done a 120y strut conversion and it is all sweeet apart form the camber and ride height,
how much do i need to cut the spring or strut to return it to standard ride height. I am also lowering the rear by 2 inches so this will need to be taken into account when resetting the struts/springs. What can you suggest cutting the springs or chopping the struts? Also where is the best place to get new ball joints, draglink and tie rod bushes, i really need a new draglink as the ballgoints are worn and not replacable in Adelaide
thanx in advance
cheers
Posted on: 2009/5/26 12:08
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Re: 120y strtus into 1200 ute help!!!
From hastings,vic
looks like u have used 120y strut tops,if so put 1200 ones in
camber will get better at right ride height
cut 1200 springs or 120y
tommo
ps, is there a motor in there ???
Posted on: 2009/5/26 12:46
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From SA
OHHH thanx heaps mate,
it makes scence now. yerp iv got the wrong tops on whoops!
its only the one nut on the top to change them insnnt it?
not in that pic the motor isnt in, but its still really bad wen it is in there.
cheers Daniel
Posted on: 2009/5/26 12:54
Go Hard Or Go Home
From hastings,vic
one nut off strut
3 nuts mount to tower
Posted on: 2009/5/26 13:30
Don't forget to compress the spring before removing the top nut. Pow!
Posted on: 2009/5/26 19:07
From SA
haha yer i was gona, thannx heaps guys ill do that tonight
cheers
Posted on: 2009/5/27 6:40
Go Hard Or Go Home
